Forum member @antony.charnley is going to install the digital cluster on my 2016 T6 next week.
The benefits for me, who has a Startline with the basic clocks, are:
Many thanks for your input.
Chris the Guinea Pig
- see coolant temp (cannot now)
- Oil temp (cannot now)
- Oil level (cannot now)
- Digital speed in MPH (currently only KPH)
- Aesthetic upgrade to the cockpit
- Tank capacity - he says it can be set
- Range calculations - he says it isn’t effected
- MPG calcs - he says are unaffected
- Light bleed from the edge - he says none.
- Black level of the display - he says it’s great
- Firmware updates are done over the air with a phone so no need to break the dash
- Rev redline is right for a TDI
- 2 year warranty
- Check EML is working - my understanding is the EML light should come on when key is put in to test the EML bulb. Could unplug the MAF to test it though?
- Test the gauges - there is a test in VCDS for this under instruments.
