Neither does my Instrument cluster support activation of oil pressure warning light. So perhaps just normal?
I don't think so.
P164E - it says it's passive - if you clear it, does it come back?
Did you have any warning lights - flashing coil light?
-or-
Perhaps simply replace the Oil pressure regulating valve - it seems to be fairly common failure.
More here:
For future reference. Applicable to T6 EU6 engines. Oil pressure switch - F1. Switch pressure 2.3 to 3.0 bar Oil pressure switch for reduced oil pressure - F378 (919-040) Oil pressure regulating valve N428 (906-030) References: Workshop Manual Transporter 2016- Engines: CXFA, CXGA, CXGB...
www.t6forum.com
For the U1019 see post #23 here
.. scusa, non è questo l'argomento di questo thread, ma volevo chiederti: sulla mia Seat Leon quando tengo premuto il pulsante 00set sul cruscotto, compare la percentuale di carica, SOC, della batteria motore .... questo si può ottenere anche in California? ... Grazie goeie vraag, ek sal...
www.t6forum.com
