T6 Aftermarket Digital Instrument Cluster
Posting a follow up to this - I contacted the seller on AliExpress and they were very nice and sent me the PCB for about £10 including postage.
After fitting, the HDMI port it sticks out this hole on the right...
I purchased a 90 degree HDMI ribbon cable as the space behind is limited.
Did you just pay them about £10 and they send you what was needed or did they give you a link to the part required you could share?
I have a digital cluster - for an audi tt, but it seems all of these are manufactured by the same people as is the software/firmware for them all.
I have a V1 which has the RKCast screen mirroring module inside. Mine does have an HDMI port but it doesn't work, I suspect the RKcast in mine and yours were probs the same, so would love to get my hands on the PCB that replaces the RKCast bit. Even if it didn't work, for the sake of £10 I'd like to take a look at it and see if it could work
I messaged the seller to ask for the HDMI PCB and they gave me a discount code for a different but similar product in their store to make it cheaper when I purchssed it. Then they sent me the PCB and not what I purchased.
Bit dodgy but they were ace!
Hello, I've managed to launch the panel. However, the Driving range readings are incorrect, always showing 0 km and occasionally flashing 470 km. How can I fix this? Please refer to the video for more details.
Have you properly set the tank size? But for me the main culprit would be that the unit is failing to adapt the setting in your instrumentation settings. VCDS into instrumentation module, then 'adaptation', then change 'Units Distance Measured' to Km. You most likely wont see this flim flam any longer. I'm pleased to see they are trying to press the change. But unfortunately still not quite hitting the mark. I have only campaigned for this for a year, but my settings changes after hours of trying things still seems to be the best answer.
Unboxed mine today, and there's a possitive wire?, anybody know if it needs connecting and if so where to?
yes thats usb' and also have hdmi built in the back, would the red wire be to swap with the yellow if required like some radios require?
The hdmi is for connecting to radio if it has hdmi out or an android box so you can have it show radio display inbetween the clocks.Can you not ask the seller for any instructions
