T6 Aftermarket Digital Instrument Cluster
Has anyone had the tyre pressure warning come up on their cluster? Yesterday I got a bong noise while going round the M25 but no warning for anything on the display. When I reached my destination I plugged in VCDS and had a tyre pressure low warning. Bit of an issue if the warning doesn't show up!
So far my noted list of unknown bongs are (but not limited to):
  • Service due in
  • Service overdue (forgot to reset it after i serviced it the other week and the penny dropped on Tuesday)
  • Tyre Pressure
  • Windscreen Fluid Low
Oh, I thought maybe it was just my config but how has tyre pressure warning been overlooked especially how it gives a DTC that's readable over CAN?
Service bongs and probably windscreen washer I can live with but tyre pressure is a big issue.
Does seem like a bit of an oversight but i imagine one that is easily rectified with an update
It would be nice to have somewhere updated list of issues with this digital dash, just to inform what are the "risks". I would buy one, but tbh I'm following this thread from beginning and I'm not sure what are exact issues and trade offs... So cannot even consider buying due to uncertainty that something will occure after installing it and my wife will kill me :D
The other thing to add to the list for me (version 1) is the brightness settings for day and night don’t work. The screen only follows the night time setting. OTA updates don’t seem to work anymore so it doesn’t look like the issue will be fixed.
Ahh, I have the same issue, do you have DRL?
I found if you start the car with them off the dash will be bright but it won't change once you have started the engine.
Interesting, Yes I have LED headlights and the tail lights are set to come on all the time. So the dash mist think it’s night time always.
Sounds exactly the same as mine (V1 dash too although never had the OTA updates work, firmware was jan 2025). Try turning the switch to off rather than auto and see what happens?
I'm sure there must be a newer firmware version out by now.
Maybe @antony.charnley could weigh in?
Gave it a try this morning, it’s not worked for me but my side lights are coded to come on with the DRLs so maybe that’s why. Unless it’s something to do with the ambient light sensor in the original cluster that’s now constantly in the dark
Ahh, yes I may have changed mine while I was testing (was a while ago now)
If i understand corrextly there is no connection made inside the board of old cluster and new cluster. So in theory with an long enough y cable we can keep the original cluster somewhere else (under the seat etc.). Am i right ?
Ps. I also asked the same question somewhere in your youtube but i could't find where it was. So if you already gave the answer sorry :)
Theoretically yes.
if your carefull you dont need the whole cluster...i did this a while back. i dont leave it connected all the time, but hady to be able to connect it up if/when required.
I put my screen in a 3D printed case with a protective screen to keep it safe.
I keep mine like this love it.
A few things are not right.
The mileage to fuel left is incorrect
And just have to adjust the map size but really happy.
I just updated FROM a September 2024 software version TO a June 2025 software version after asking for an updated firmware from the support in China. I have a V1 with no HDMI, only wireless mirroring/USB CarPlay
Update seems great so far but alarmingly my car had a low engine oil warning which I didn't see until this new version was applied.
Yes, I know I should be checking the oil level manually and checking - must've been about a month since I last checked.
Other updates which pleased me was the ability to change the colour of the whole van, not just the top half.
I'll use the dash for a few days and let you know what else I've noticed. Unless anyone has access to a some well documented release notes ??
This isnt something they seem to provide im afraid which hurts my brain a little.... when i was doing that sort of stuff and took great pleasure in documenting the smallest of changes for a new release of code and actively notified customers when a new release was available etc.
Did this release solve the MPG issue do you know?
I had exactly the same issue with that update, I rolled back to the previous one which was March 2025
Yeah last night I checked the oil levels and it was fine. I also checked using Carista and there were no engine fault codes. Makes me think its the firmware and not the van.
I've reported the fault to the developers.
Did this release solve the MPG issue do you knoknow
Well it didn't fix the distance remaining in the tank issue, I still had to manually set the car distance units to km via Carista to correct this. Unsure about the MPG yet as I've only driven it 5 min up the road and back.
