T6 (150hp) Engine Squeaking/Chirping (video attached)
smig
I have this squeaking / chirping noise coming from the belt area. Is there a known issue? Sounds like a bearing issue. Anyone had this and resolved it?
Auxiliary belt and tensioner. It’s a common issue. I had mine replaced at a local indi recently.
As mentioned above, it’s the aux belt tensioner. Mine was the same. There are various other posts on here covering the same issue.
Good evening all, I have the same noise, does anyone have the part number for the tensioner please, T6 2017. Thanks
Hi all. Similar problem here. Put it down to cold weather but appears to be getting worse. I tried downloading the aux belt and tensioner replacement guide but it doesn’t seem to allow me (registered as vip member) does anyone have any guides and is it easy to do (semi competent I suppose) thanks
