T6.1 Led doorstep light unit
Kromwell
Hello! Anyone knows if T6.1 LED door step lights fit to t6? Or are the plugs different? If so, is there any adapters available?
That socket looks different to the to the caravelle ones I have fitted to my T6. The caravelle ones I’ve fitted also have different plugs/sockets to the original step lights that were fitted from the factory. This may be different on a T6.1. Do you already have the larger step lights like you’ve pictured or will you be replacing the step too?
It already has larger step lights with "Multivan" writing but I can't check the plug because the van is still in transport.
Just unclip the silver cover that has 'Multivan' on it and replace with 'bulli'. You won't have to mess around with the wiring then :thumbsup:
Good idea, thanks! Only problem is that Multivan light is halogen but i'd like to have all interior lights LEDs. Will have to find correct bulbs then if there is no other option (plug-n-play adapter or something simple :D) but to re-do the wiring.
This is what I did
