Hi all,
I have a 24 plate kombi,
I cut off the rear lights and installed Some led spot lights.
They have been working for 14 months and then the van went into vw and came out with the lights not working.
It’s been back and apparently there is a short on the pos leg of the lights to ground coming from the j159.
It’s now back to factory with the cables in a connector block as they said it was my wiring or lights.
I am a sparky so know how to wire etc etc
They said the lights may have damaged a module etc
All been fine since vw had the van.
They said the lights are on the can bus and may have caused issues, but this pos to ground short has not blown a fuse at all.
I would have thought the can bus would have bout a fault code up straight away if it didn’t like the lights but have been working for 14 months with no problem.
Any thoughts on this, would led spots be ok on the original wires for the interior lights ?
Any help would be appreciated, also would anyone have the part code for the original plugs for the 2 pin plug for the interior lights ?
Van is now stripped out but I am sure it’s not wiring.
Many thanks
Many thanks
