T5.1 to T6 climatronic panel retrofit HELP!
Adams
VCDS User
I currently have the T5.1 (2015) climatronic panel fitted like this
And I have the T6 one I am trying to retrofit, pretty much only to have a functional heated screen button as I couldn’t get the T5.1 panel to do it.
From looking at Elsa there are only a few wiring changes to make on the flap motors, but even with them done I can’t make it work. The relevant flaps don’t function properly and keep throwing up faults such as actiator stuck and no basic settings (even after carrying out basic settings) I’m thinking I may need T6 actuators??
If anyone has any ideas it would be appreciated
other than the actuator motor wiring being the opposite way around on a couple of them, the potentiometer pin assignment is different between the T5.1 and T6, but the actuators are still the T5.1 ones so in theory wired the correct way?
T5.1 actuator wiring
T6 Actuator wiring
I’ve been looking at the flap actuators and the T5.1 one is 120° and the T6 ones are 340°.
I’m not sure if the flaps are controlled differently between the 2 units. It I could only see that if I had the 2 heater box’s side by side
