Hi all,
I've been battling this for months.
2009 T5.1 Caravelle with common knackered electric door cable failed on the LHS (passenger side).
I've ordered the replacement cable set to avoid shelling out £500+ for entire new motor and cable assembly from VW but my plastic spool is also a bit tired and I'm keen to renew it if possible.
Problem is everything I order seems to have a different centre pattern to my original one and doesn't work?
Any one had similar and solved this issue? I've had 3 kits now and all wrong, despite the adverts showing photos of the correct part that I need?
