Yes. It's the same part number for the level sensor on both vans. The bracket has a semi circular cutout in it that is large enough to clear the ARB on all models.
The level sensor bracket is the same but the arb bracket has a different rubber insert inside the metal piece
The arb can vary in size dependant on model, i think it 21mm or 23mm or 27mm so the rubber is different to match
hi,whats the reason you need t32 antirollbars,are you removing uprated ones or are you upgradeing from t26/t28/t30 etc,just interested in reason,i may have a set (soon)looking to uprate mine on t32 to( h&r) thanks
hi,sounds great interested in my antirollbars,i am looking to upgrade mine as soon as i can,im interested to know your van weight and why you require t32 bars,you by chance havnt H&R bars to swap or why you not fancy H&R thanks
