T32 ARB polybush part number?
mwg99
Could someone please confirm the part number for a set of Powerflex polybushes for the front ARB on a 2016 T32 Sportline.
Many thanks in advance.
I read somewhere it may be 28mm, but the Powerflex bushes only go up to 25mm. Europarts told me the OEM bushes are 24mm. I'm a little confused by it all, which isn't easy to be honest!
Get yourself a cheap vernier calliper and measure the roll bar.
Just in case anyone else is wondering....
Powerflex Front Anti Roll Bar Bush 25mm part number PFF85-1303-25. This is the replacement for OEM Bush Part Number 7H5411313B.
Thanks for your contributions.
Make sure you soak the ARB bush bracket retaining bolts with penetrating oil for a couple of weeks before attempting removal or it could turn ugly with sheared bolts.
Best have new bolts to refit with anti-seize grease.
I have a set of T32 ARBs to fit (cheap upgrade for a lower weight van) and have these from Steve at CRS.
Code for fronts is as per above
Rears PFR85-1313-28
