Sump Replacement
Rabonitez
2016 T30 102PS CXGB
Does anyone have any experience with removing the sump? I need to replace mine (T6 CXGB) as it’s cracked. I’ve had a look and it seems there are x3 bolts holding it to the gearbox and multiple 10mm bolts around the sump connecing it to the block. X2 of these bolts look difficult to reach from underneath the vehicle as they are obscured by the flywheel housing. See pic for bolts I’m referring to.
Hi there, never removed a sump from a 2.0 but would expect it to be very similar to 1.9. The fly wheel can be rotated and there is a slot to make it easier to get to the bolts. They are usually torx and you can use a torx bit rather than a socket. There will be plenty of you tube video for sump removal on a 2.0.
