Hi not sure what happened.
When to pick up fish & chips last night in the -2 weather drone for 20mins fine and on way home it suddenly cut out with no warning.
Managed to stop at side of road & called AA.
This is a video of what was happening.
The errors are:
- ESC (stabilisation error)
- Acc error (not sure if this means front radar sensor or it means ignition problem as in acc power)
The main battery was very low 11.4v so I tried connecting to my leisure batts and it went up to around 12v and no more errors! but no crank.
The AA man arrived and used his battery booster to give 12.6v but again no crank.
Also nothing on diagnostics as it no connection...
I got it recovered to my local garage but they are busy for 10days.. so today I tried a few things.
Have removed all my electic mods incase there is a short somewhere (I doubt it)
So this included removing my inline stereo amp and could be something wrong with harness. For last few months the amp hasn't been always turning on (which I think might happen if it detects low voltage on the battery?
Everything else I have runs off the leisure system so I have isolated that by disconnect the ctek 250se main batt line.
Thinking of pulling out the main battery tommorow & checking the relays. Is it easy to test a relay?
I guess very worse case there has been an ECU error and it needs a new expensive ECU but I'd like to try some other things first..
The errors are:
