£50 a month for 50gb roaming. But it’s a lot cheaper in Europe.£95 / month isn’t cheap, I think I’d rather have a portable solution if I were travelling in a remote location, something like an Iridium phone.![]()
Starlink | Roam
LIMITED TIME OFFER - ENDS MAY 28th $299 $499 FOR THE MINI KIT Work and play at remote locations, starting at $50/mo.www.starlink.com
I’m pretty sure I was reading that Apple were introducing sat network capability in the very near future.
But Kate but see my reply above. It would not work in the van mounted in the pop top. DC power is what powers it and it uses 25-40w but mine would not work on either my USB C or 12v sockets.Has anyone done a permanent install of the starlink in motion RV solution?
If so, can it run of DC power or did you have to run through an inverter?
And
Did it work mounted on a pop top, with the pop top both up and down?
This is my worry too…. 12v sockets not up to itBut Kate but see my reply above. It would not work in the van mounted in the pop top. DC power is what powers it and it uses 25-40w but mine would not work on either my USB C or 12v sockets.
EcoFlow mate. Www.EcoFlow.com a few of us have the Delta 2. Great bir of kit. I use a Victron 12v 200va inverter for mine and my bike.Brilliant @Mick - thank for sharing your experiences. I too have misgivings about the USB solution even with the updated throughput. I’ve asked @Dellmassive to share some thoughts on what inverter I should consider. Have you got a pic of the ExoFlow you are using. The young lad and I are off to google it.
By the way, I also bought the 3d printed mount and I have some helicopter twin-stick tape arriving soon as I’m going to try mounting on the roof
Can you send details of your mount? Mine is internal.Brilliant @Mick - thank for sharing your experiences. I too have misgivings about the USB solution even with the updated throughput. I’ve asked @Dellmassive to share some thoughts on what inverter I should consider. Have you got a pic of the ExoFlow you are using. The young lad and I are off to google it.
Magnetic mounts (the black disks) but they won’t work on the aluminium roof of my Cali. I was thinking of gluing some large metal washers to the roof for the magnets to “grab” but I’ll probably unscrew them and use twin-stick 3M tape directly between the mount and the roofCan you send details of your mount? Mine is internal.
I am looking at sticking it to a roof light in my new van a Weinsberg X Cursion MQ 500 on a T6.1. chassis.Really interesting seeing people's setup.
I use my van from time to time as a mobile office (All I need is a macbook and an Internet connection to work). I have got a Kuma 4g router and puck antenna mounted on the poptop and found that great for YouTube (keep the kids amused while driving) and security camera. But just not quite enought for work video calls.
The starlink has been flawless for that.
I use it connected to a Jackery and magnetic mount it on the bonnet but I've also had it on the dash without issue. Although I do find having it as close to north helps for full 200+ connection.
Those magnets of mine would need a longer screw “stem” to work on your mount.Can you send details of your mount? Mine is internal.
I can see how you made up your magnetic mounting now. Nice neat solution for when parked up.Really interesting seeing people's setup.
I can confirm what my 12v sockets aren’t up to it! Might have to go the inverter route!!!This is my worry too…. 12v sockets not up to it
Yay! A proper electrical system!I can confirm what my 12v sockets aren’t up to it! Might have to go the inverter route!!!
Yay! So I sought the support of a proper electrical engineer!Yay! A proper electrical system!
