Solar panel to trickle charge leisure battery
Welcome to the forum.
Do you mean a portable plug-in one, or permanently stuck to the roof?
Thanks for the reply, I’ve seen some solar panels that have been placed on the dashboard when parked up and if they are any good if so I’m hoping that I can get recommend one 👍
Any recommendations for a good solar panel to trickle charge my leisure battery please note it’s not a lithium battery
There is quite a difference between trickle charging a battery to see you through the winter months and keeping the leisure battery charged to (for example) keep your fridge running while you’re off grid.
Normally the leisure battery will charge when the engine is running or when the engine battery is on charge.
I have retro fit solar panels and wanted a trickle charge facilty to the vehicle battery, so after readind several threads here bought a Ablemail AMT12-2 trickle charger.
Unfortunately, it turns out the Victron controller i have installed wont allow this to be fitted and the location of the fuse board etc will require a days work to sort this out. So instead i will be looking at a foldable solar panel option.
As a result, i have a trickle charger for sale - say £50?
