Has anyone running solar had a problem with overcharging when the van is running ? mine charges averagely at 13v - 5 amp during the day , i leave the fridge on constantly and two gas detectors .
When i drive the van and it goes into regen charging the gas alarm on the back of the seat base next to the 110ah AGM battery goes off ( factory wired aux battery ) this also has a vent and the vw factory hood over it, so must be a bit of gas about , if it wasn't for the gas alarm i would have no idea it was doing it.
I understand how the van charging system works and that it bulk charges etc etc so what is the solution when you have a van set up as a camper ? obviously the aim is to keep charge in the battery but the van system needs enough room ( 20%) for it to bulk charge, is there a solution ??
Picture from first install so battery not yet full .
