Smell of fuel in cab when stationary
Domfowles77
Good evening all, firstly I'll introduce myself. Im Dom from Leeds, I'm fairly new to the Transporter scene, bought my T6 about 7 months ago. It's safe to say it's not been an enjoyable experience thus far.
Shortly after buying (privately) my Van (the dreaded pre 2018 Biturbo) i realised it wasn't right, burning a lot of oil and constant DPF/EGR warnings.... basically the engine was cooked. I made the decision to have a new engine fitted, at great cost. They replaced the engine, Turbos, EGR, Flywheel and a few other bits, almost £16k later i got the van back. Immediately when driving it i noticed a strong smell of fuel/oil when idling. I reported it back to the garage, took it back, they checked it and said it was fine and was likely some residue that was burning off, and to try do some miles to clear it. I did this and the van soon started cutting out when idling. I parked up and noticed a large pool of diesel under the van.... it'd blown a pipe off 😳. I got the van recovered to the garage and they repaired the pipe and deep cleaned the engine/bay. That was almost 2000 miles ago and the smell still exists and is getting worse. I've messaged the garage and they're now saying that if it's a preexisting issue I'll be charged for the repair, which is insane considering they replaced everything 😡
So I suppose my question is, what do you guys think is causing the smell (which appears to be more on the drivers side of the engine bay) ?
Many thanks
Dom
  • Sad
Stupid question but have you looked around the engine bay for any signs of wet patches? I had an issue where a fuel pipe split and fuel ran down the front of the engine and when warm it smelt but with the bonnet open I could see a mist/haze. Might be worth taking engine covers off for a better look. Has the pollen filter been swapped?
Many thanks
Dom
You say ‘they replaced everything’, they clearly didn’t; they replaced the parts that you listed.
IMO they are being reasonable in stating you’ll be charged, especially after 2000 miles.
Yeah, there's no sign of any leaks, I've been pointed towards a possible split hose on the EGR valve (which they replaced)... pollen filter was replaced yes.
This issue started immediately following the work carried out (never happened before the work). It's been back to them twice already and they literally told me to put some miles on it to try sort it (as they said it was spilt fuel that needed burning off).
