Slight knock sound over bumps
Jfoz
I've recently had new Heavy duty arms, ball joints and drop links fitted. But I still get a knocking sound over certain bits are certain low speeds, less frequent since the new parts.
Do these need revisiting to tighten any nuts/bolts or is there something else that could be causing the sound.
Is your van quite empty at the moment and do you have coil overs? When van is empty on coilovers some times a section of the springs that are normally touching are only almost touching when van empty and they can knock - generally at the rear.
A leaked of oil and empty front damper can cause knocking.
Exhaust mount perhaps?
Loose spare wheel bracket, side bars etc?
Not telling you what your problem is, but after I changed my drop links I had to retighten them a few weeks later to stop a slight knock.
If you've got the facilities to do it it's probably worth seeing if you can tighten them a bit more since they've bedded in. I try to do mine with weight on the hub, rather than with it hanging there, as that's more like how it is when you're driving.
Yeah van is empty currently, used as a work van. No coilovers just the factory springs and shocks.
I'll have look and the other 2 you mention 👍🏻
Could the engine mounts cause knocking sound?
Yeah I'll look into this, taken it back within this month for my pads and discs, will have them tighten it up then
I had to do exactly this as well.
Definitely go and check how tight your drop links are before anything else.
Still persists, knocking/clunk sound. I can go over multiple speed bumps and not hear it, then drive down a poor quality road with dips and divet, pot holes and it can be heard a lot.
Drop links, arms, bushes all replaced and tighten again during pad and discs change last week. Any suggestions what it could be?
I know my clutch and flywheel is coming to an end and will likely need changing, could this cause that sound?
To access the top mounts you need to remove the scuttle panel at the bottom of the windscreen - remove the two 13mm nuts holding each wiper blade on, prize these off and then unclip the plastic scuttle panel up from the locating channel across the base of the windscreen.
Then you need to remove the two small metal access panels on the bulkhead at each rear corner of the engine bay (one behind the airbox and one behind the battery). Think they use 2x T25 torx machine screws off the top of my head.
The top mounts are under a rubber boot which just pops off - check there isn't excessive wear to the mounts and that the nut is torqued to the correct spec. (about 50Nm if I remember right)
