sliding door internals - rubber drain at the bottom
PJfamilyguy
Hi all,
Does anyone have an exploded diagram of a T6 sliding door, I want to know what the drain plug at the bottom connects too
Hi
There is a drain pipe that runs from the electric door moto from what I could see
brilliant, thanks I wish I had access to that screen with that info !
Can you access all of that from the inside ? ok what I mean I wonder how I can flush some water through the funnel and out the bottom, without taking everything apart.
Thanks again.
Just take the inner panel off and you will see it. why would you need to put water down it ? :confused:
and I'm getting tiny rust particles on the door sill after it rains.
I'm thinking its just from the swarf from when the window was cut out, but would like to flush them all out rather than sit their and fall out over time.
On mine it drains water that gets in via the door handle, perhaps if you held the handle open you could get some water to run through without removing the card.
