Single to double seat switch, issue
thebuzz555
Has anyone switch from a single to a double seat?
I’ve lifted everything checked the floor and mine doesn’t have female threads to accept the bolt for the seat base. It’s just a hole.
Could this be because it’s a factory single?
Same here. You need to get 4 of the bolts and fix them.from underneath. You can get to 2 easily but the other 2 are under the adblue tank if you have one
Make sure to check your airbag too. If it's a factory 2 up front then you may have a single airbag. It isn't wide enough in the worst case scenario
