Hi all
I'm hoping someone has come across this before.
I have a 2017 VW T6 camper with a Sargent EC50 power system and a Victron SmartSolar MPPT.
The MPPT had disappeared from the Victron app, so I removed the seat and found/corrected a wiring issue.
The MPPT is now back online and charging correctly in the Victron app.
However, since then the Sargent EC50 has developed an intermittent fault.
Symptoms:
Powers up normally.
After a short time it beeps twice.
All the LEDs briefly illuminate/red.
The control panel then shuts down.
A couple of points:
The vehicle battery is not connected to the EC50, so pressing V always shows one flashing red LED, which I believe is normal.
The leisure battery (L) works normally.
The fault disappeared for a while after reselecting L, but it's now returned.
The Victron MPPT continues to appear in the app and seems to be charging correctly.
Before I start replacing parts, has anyone seen an EC50 do this?
Could it be:
an intermittent leisure battery connection,
a fuse or poor earth,
the EC50 PSU itself,
or the control panel?
Any suggestions or known faults would be much appreciated.
Symptoms:
Powers up normally.
A couple of points:
Could it be:
