C Cjscos Member T6 Pro 25 Jul 2020 #1 Good evening all. Can I run 6 x 2.5w leds from the original factory lights or will they need a dedicated circuit?
Pauly Senior Member VCDS User Admin Moderator 25 Jul 2020 #2 If you are removing the original fittings then you are actually reducing the load, factory is 2 x 10w lamps so you will be going from 20w down to 15w
C Cjscos Member T6 Pro 25 Jul 2020 #3 I have swoped the originals filamnets to ledsi think they are only 2w. That great news. Many thanks for your help pauly
