Hello m'hearties.
I do seem to be posting a lot. A new T6 owner... !I hope this will calm down at some point. You might recall that my partner was sold a T6 with an EGR valve/cooler made almost entirely of coal.
The business refused to accept a return (and my partner is a business, not a consumer) so now she owns Tony the Transporter - 2017 T6 panel van, 5-speed 102hp, 125,000 miles. Court case to pay for the repairs. Hopefully, not too many more nasty surprises - but I'd not find anything surprising at the moment. For example - discovered that the bastardos replaced the spare wheel with... an old, bald tyre!
The vehicle has had a shiny new EGR now. Before that, our trusted mechanic tried to clean the one that was present. Unfortunate this didn't work - the cleaned EGR cooler had a small rupture and Tony drank half a tank of coolant right through his engine hole. The coolant was removed and a genuine new EGR fitted (no extra labour charged). There was also a persistent issue with the oil pressure switch, which was tracked down to be a high-pressure valve which only opens about 2500rpm.
Tony now has a rough idle when cold which I'm pretty certain wasn't present before. Fairly minor, but there. Clears up after a short drive. He also has what could be a misfire or an engine wobble at 1200rpm - I can still get this to happen in neutral after a 100-mile motorway journey at 70mph. Generally feels a bit juddery on the motorway under acceleration - but I don't have anything to compare it to, as I'm not used to these vehicles. Doesn't feel underpowered. Start-Stop is available after a long journey like that, but is no longer available the following day.
Flywheel and clutch were replaced recently according to service history. No smoke from exhaust.
I am now the proud owner of a VCDS. I ran the auto scan and didn't get anything relevant back other than:
31103 - SCR NOx Catalyst Bank 1
P20EE 00 [01100000] - Efficiency too Low
This is the DPF (joy) and was also picked up originally.
I have had the ECU out and can report it is stock firmware.
Mechanic says that the rough idle may sort itself out as the vehicle 'learns' the new unobstructed EGR and adapts it's 'active map' (which is apparently a map based on sensor data such as temperature and driving conditions).
I was hoping, as ever, for a bit of advice.
It seems likely to me that the rough idle / mis(ish)fire are probably related to the mechanical work - would you guys agree?
I’ve read that the MAF sensor might want cleaning/recoding - but not sure what that really means.
I’ll be looking to teach myself how to log live data and make analysis via VCDS. Until that wonderful day - might one of you suggest an approach for logging this? The rough idle isn’t concerning, but the potential misfire is.
Thanks as always!
X
Thanks as always!
X
