Replacement Towbar 13 Pin Socket?
Garyde
Hi All,
My T6 kombi was supplied new with the usual Westfalia detachable towbar and associated electrics socket. I recently used this for the first time and discovered that the indicators weren't working (all other lights worked fine). Looking at the socket its obviously badly corroded which will be the culprit. I am presuming its possible to replace the 13 pin socket with a new one, but when i do some forum and google searching i cant find any mention of anyone having to do this or a part number for a direct replacement.
Can anyone advise where I can get a like for like replacement 13 pin socket and if it is a straight forward replacement.
Thanks as always for any help anyone provides!
incase anyone has this issue in future, I replaced the socket with the one in the link above, fairly straight forward, the only thing to be aware of is the cables are crimped to the pin connectors instead of screwed in (like a normal 13a plug).
