Rear wiper and washer jet
cowgoesmoo69
I've got a droopy wiper at the back. Tried to undo the nut to adjust but it seems pretty solid, gave it a good spray with WD40 and left it for a few minutes as well, doesn't want to move. Any ideas before I get a bigger spanner out and probably snap something?
Also the washer jet is missing from the end. I've seen some replacement washer jets and it seems to suggest you just push it in, is it that simple? If so, I'll order one.2026-03-31 16.28.59.webp
Had a closer look at it yesterday. The nut did release with a socket on it, and used an arm puller to remove the arm and try and reposition it. I think the motor is on its last legs though, so much play that I couldn't get it into a satisfactory position (putting it in a better start position meant that it overruns at the other side when it operates
:rolleyes:).
And looking more closely in the end of it the previous washer jet was snapped off, can see the remains of the plastic inside the hole. Guess I'll be changing the motor out then.
