Rear Door Lock Assemble Removal
RocketDude
This is my first post here, so apologies in advance if this has already been posted ...
I'm in the process of converting my T6 into a camper and am applying lots of sound deadening. I want to apply some to the rear doors behind the lock assembly (barn doors). I can get everything off the big assembly plate except for the pushrod attached to the exterior handle. How do I disconnect this? Everything else seemed to come off without too much force but I just can't seem to get it disconnected! What am I missing?
Many thanks
Picture ?
Normally the push rods have a 90 degree kick in the end and you have to twist the plastic latch to the side to allow the rod to pull out
Welcome to T6F =]
this any help?
Removing and installing exterior door handle:
Special tools and workshop equipment required - Torque wrench -V.A.G 1783-
Removing
– Remove carrier → Chapter.
– Disconnect connector -3-.
– Undo and remove bolts -2- and remove exterior door handle -1- from wing door.
Installing
Install in reverse order, but note the following:
Specified torques
Component Specified torque
Exterior door handle 8 Nm
VIP Membership | VW T6 Forum - The Dedicated VW Transporter T6 Forum
Removing and installing assembly carrier
t Torque wrench -V.A.G 1331-
Removing
– Remove trim for wing door →General body repairs, interior; Rep. gr.70.
– Disconnect connector -3- from assembly carrier -1-, and remove cable ties.
– Unclip pull rod for lower lock -4- and pull rod for lock cylinder relay lever -6- from latch carrier.
– Unclip Bowden cable for upper lock -7- from latch carrier.
– Unscrew nuts -2- from assembly carrier -1-.
– Unscrew bolts -5- and -9-.
– Guide assembly carrier -1- downwards.
– Pull pull rod for exterior door handle -8- out of latch carrier.
– Remove assembly carrier -1- from wing door.
Installing
During assembly, ensure that all pull rods, the operating rod and the Bowden cable are clipped in place correctly.
Before installing the wing door trim, check the function of the release components.
Specified torques
Dellmassive,
your answer was spot on! I was trying to disconnect the pushrod (8) from the TOP, I didn't realise that it came off at the bottom.
Job done!
Many thanks all
Rocketdude
