program a remote control
gerry
France
VCDS User
Hello
in case of replacement of the bcm 09 should the remote controls be reprogrammed?
thank you gerry
Yes the keys will need to be relearned, it can be done via adaption channel with VCDS
Step 1
Module 09 adaption channel 0
Set to 0 then test & save - this will clear any existing key programming
Step 2
Module 09 adaption channel 1
Set it to 0 then test & save, press unlock on the keyfob, hazards will flash to confirm key is learnt
Repeat step 2 for each keyfob
Reactions: mmi
For future reference i should point out that step 1 is not necessary if you are simply adding a keyfob to an existing vehicle/bcm otherwise you will have to reprogram ALL keyfobs unnecessarily
Reactions: mmi
