alexhammond
Hi Everyone
First post, first camper, newbie all round, but wanted some opinions if possible...really appreciate any thoughts.
Story so far.
- New conversion from pro converter (unnamed for now) June '21
- Coil and engine light popped up 50 miles on the drive home from purchasing it (amber)
- Local garage fixed it, (Replace exhaust gas temperature sensor & Replace EGR cooler, fill in new coolant) original dealer paid for that bill.
- Follow-up fault with START STOP ERROR on dash, again fixed by the local dealer (Check vehicle for engine fault regarding body control module communication, check wiring from battery monitor to alternator as per garage request. Remove loom, trace fault around oil cooler area, repair loom and refit, clear faults, no engine faults on test. Original dealer paid again.
- 1000 miles later, coil and engine fault pop on again. (amber)
- Local garage has advised the error is fuel injectors and fuel rail need replacing at £2500+VAT
Van is 2017 Startline, with 84k miles. But done less than 2000 miles since i've had it.
My Warrantywise cover say it isn't covered and so i'm looking at a big bill less than 3 months after spending a lot on the van in the first place. Pretty unhappy about that.
Original garage said that after 30 days it wasn't their problem and all 'responsibility fell to Warrantywise or as the case may be, me.
Is this just bad luck? or associated problems?
Are the original dealer right in saying it isn't their problem?
All and any thoughts really welcome.
Alex
Story so far.
Alex
