Power latching soft close motor replacement - T6 Caravelle
Bikesvansnplans
Hi,
Has anyone replaced this motor? I'm having the issue where it tries to pull in the door to power latch 2-3 times then just gives up. I have removed the rear trim panel and can see the motor. Just wondering if anyone here has replaced and if there's a good test to know if this motor is the issue. I can see they are £300 to replace so would be good to be sure.
Also, anything to be aware of when replacing? Looks like the task is to remove the striker plate then remove motor and replace
See this link
The module is in the rear quarter between the wheel arch and back of van, not very logically as you would expect it to be in or next to the door
