Pop Top question.
Belly
Do you lose head height to the front seats with a poptop , factory swivels so no adjustments..
Ultimately, it depends on which roof, but usually you don't lose head height at the front. Typically, with a stealth roof, where the lifting mechanism sits below the roofline, you will lose height at the back and that loss tapers to nothing as you move towards the front of the van. Not sure what impact factory swivels will have.
All pop tops retain most of the factory headliner in the cab or at least modified to facilitate roof access. All those that I’ve seen and I’ve had a horizon roof and a vanmax didn’t reduce head height in the cab
