So this week I will start to install all my electrical kit in project 'Wolfgang'.
I have tested the solar panel with the Victron MPTT and it works great, giving a great output.
I have also tested the victron 30 amp mains charger, but the rest of it is still in the boxes.
I have not yet linked the batteries in parallel, but will do as soon as my battery box is finished later tonight!!
I have a few questions, one regarding the need for a physical battery isolator coming off of the battery bank, do I / should I install one?
Cost is fairly cheap for a 350 amp rated model.
The next question is regarding the invertor, which is a 2000 watt PSW model from Renogy. The chart I found for a 2000 watt invertor says to use 120mm2 cable (4/0 awg) this cable is like an elephants leg. Do I need to go this big? 240v equipment will be a microwave for occasional use and the charger for my emtb. The emtb battery charger is rated at 2 amps @ 240v.
the microwave is 700 watts but will only run for short periods. Quite possibly only used if on EHU.
So you could say that the invertor is well over spec, but I liked the auto switchover and five year warranty that comes with the Rengy unit.
Do I / should I use such massive cables?
Final question is about the feed to the main 12v load fuse box, I was thinking that 16mm2 would be more than adequate and I have some left over, so I gusess you cant be too heavy on cable (or can you?).
Please cast your eyes over the attached document and let me know if you spot anything bad / wrong / likely to make Wolfgang go up in flames!!
I need to get cracking with this as I have booked our first trip away in the van at the end of this month!!
Thanks in advance of your helpful comments
Deaks
Deaks
