There is plenty of information on this forum in regards to how to do the wiring in our vans. I've learnt a lot and done a lot of reading on here. I have noticed that there are no diagrams showing a physical layout of components so figured I'd upload one to hopefully assist other.
My set up has no solar, and no additional monitoring of the battery other than what the Victron apps provide.
I've used:
- Victron B2B 30A
- Victron Blue Smart IP65 12v 15A Charger
- Wylex WBE3 3 Module Insulated Enclosure × 1
- Wylex NHXS1B10 10A 30mA SP Swi. Neutral B Curve 6kA Type A Mini. RCBO × 1
- Wylex NHXS1B16 16A 30mA SP Swi. Neutral B Curve 6kA Type A Mini. RCBO × 1
In my eagerness to run the wiring from the engine bay to the driver seat, I inadvertently ran the following:
- 240v flex in blue - this is to provide a 240v feed to sockets in the kitchen unit,
- 16mm single core wire in red - this to to connect from the starter battery to the B2B which will be under the drivers seat
- 0.5mm twin core to provide a feed from the Victron battery under bonnet to leisure battery under drivers seat. This is the issue since it only has a rating of 11A, so is absolutely useless to use for the 15A charger. (Edit: I later replaced this with a 3mm 33A twin cable)
I'm left with 1 definite option:
- remove seats, carpet etc and run a larger cable - not an appealing task to have to do again.
And one possible option:
- connect the battery charger to the starter battery instead. I did read on here (but now can find it) the this was a possibility. The thinking being that when on an EHU, the starter battery charges, and the B2B then kicks in and charges the leisure battery.
Can anyone confirm this 'possible' option please, or point me in the direction of that thread.
TIA
I've used:
- Victron B2B 30A
TIA
