Paint came off removing high level rear light - best thing to do ?
nodecentral
Hi all
I’ve just removed the high level rear light and due to the adhesive used, it’s taken some of the paint off with it. (See photo)
Before I stick a new one light cover back on, is there anything you would recommend I do to the area first ?
I’m not sure that you actually took any paint off!
It looks more that various adhesives/sealants have been used. Give the whole area a good clean-up and inspect it again.
Seeing as it is all hidden by the light fitting, you could just touch it all in with a small brush
It looks to be the paint, see this photo of what’s come off when I took out the high level light/camera..
Amazing to think, it could take the paint right off..
Is there a primer/paint I should look to use, as I expect a little bit will be exposed when I put the new light/ camera in ?
Just pop into HalFrauds and pick up a touch-up paint bottle with brush in a similar colour if you believe it is paint. It is in an area that doesn’t get seen (but that also makes it the reason to make sure it has a coating!)
If you’re really stuck, nick your other half’s clear nail varnish - it will do the same job!!!
