Is this a change in engine behaviour - that is didn't happen earlier?Its been on around 4-5 times in 5000 miles.
Was the light on in the posted picture - as the status is only "Intremittent" instead of active?Engine warning light comes on, I scan it and it's this everytime.
I have only had the van around 3 months so I am not sure on this. Seems to be on longer drives. I have also had the 600mile ad blue warning that decided to correct itself after 30miles, this has only happened once though in the last 1000 miles.Is this a change in engine behaviour - that is didn't happen earlier?
Yes it was onWas the light on in the posted picture - as the status is only "Intremittent" instead of active?
Please post details about engine
OBDeleven > Control units > Engine > Info
(no need to connect to the vehicle - should be available offline)
Car: Volkswagen Transporter
Year: 2018
Body type: VAN
Engine: CXHA
Mileage: 221270 KM
01 Engine
System description: R4 2.0l TDI
Software number: 04L906056KL
Software version: 3802
Hardware number: 04L907445
Hardware version: H02
ODX name: EV_ECM20TDI03004L906056KL
ODX version: 004003
Long coding: 00194014435501090000
Trouble codes:
P204F00 - Reductant System Performance Bank 1
Intermittent
P20EE00 - SCR NOx Catalyst Efficiency Below Threshold Bank 1 Catalyst 1
static
Date: 2068-01-23 15:16:48
Mileage: 220808 km
Priority: 2
Malfunction frequency counter: 8
Unlearning counter: 255
Unknown ambient data: 1F23B46E813E64331D712096283F6504EC445400CD44C9149144A7180758210000000058220000004C58B2000041E30000
03 Brakes
System description: ESC
Software number: 7E0907379P
Software version: 0133
Hardware number: 7E0907379M
Hardware version: H06
Serial number: 62077000000368
ODX name: EV_Brake1ESCCONTIVN75XGP2
ODX version: 011001
Long coding: 517E4098256584848A770277A48A21E679F500
Trouble codes:
No trouble codes found
04 Steering Angle Sensor
System description: LENKW.SENSOR
Software number: 6R0959654
Software version: 0070
Hardware number: 6R0959654
Hardware version: H07
Serial number: 15071713470128
ODX name: EV_LWSKLOVW25X
ODX version: 005001
Long coding: 01
Trouble codes:
08 Air Conditioning
System description: Climatic-T5
Software number: 7E0907047AK
Software version: 0708
Hardware number: 7E0907047AK
Hardware version: H22
ODX name: EV_ClimaticT5
ODX version: A01003
Long coding: 0000000003
Trouble codes:
09 Central Electrics
System description: BCM PQ25 Max4
Software number: 7E0937090C
Software version: 0752
Hardware number: 7E0937090C
Hardware version: H82
Serial number: 4000 206170556
Long coding: F8AC393A0A33201100280F742E6B8C550F96710F60464D60330400230840
Subsystems:
System description: J386__TSG_FT
Software number: 7E0959801P
Software version: 0653
Hardware version: 003
Serial number: KU0KU026071772070043
Long coding: 1400B0
System description: J387__TSG_BT
Software number: 7E0959802P
Serial number: KU0KU026071772074526
Long coding: 0400A0
System description: E221__MFL-MD9
Software number: 7E0959442A
Software version: 0103
Serial number: 39190001260890059213
Long coding: B40000
Trouble codes:
13 Adaptive Cruise Control
System description: ACC Bosch PQx
Software number: 7N0907572
Software version: X055
Hardware number: 7E0907572
Hardware version: H03
Serial number: 0607170440AB76
ODX name: EV_ACCBEGVW361
ODX version: 001002
Long coding: 00004000FE0739
Trouble codes:
U140000 - Function restriction due to insufficient voltage
Intermittent
Date: 2068-12-21 11:06:33
Mileage: 220442 km
Priority: 4
Malfunction frequency counter: 11
Unlearning counter: 62
15 Airbag
System description: VW10Airbag01T
Software number: 7E0959655G
Software version: 0018
Hardware number: 7E0959655G
Hardware version: H08
Serial number: 003V3005NYGT
ODX name: EV_AirbaVW10BPAVW12X
ODX version: 001028
Long coding: 000000000000000000000000000000003154
Trouble codes:
17 Dashboard
System description: KOMBI
Software number: 7E0920970S
Software version: 1107
Hardware number: 7E0920970S
Serial number: 00000000000000
ODX name: EV_Kombi_UDS_VDD_RM09
ODX version: A05733
Long coding: 1509010300
Trouble codes:
19 Gateway
System description: GW-K-CAN TP20
Software number: 7E0909901
Long coding: 042305
Trouble codes:
25 Immobilizer
System description: IMMO
Software number: 5K0953234
Hardware number: 5K0953234
ODX name: EV_Immo_UDS_VDD_RM09
ODX version: A03710
Long coding: 000000
Trouble codes:
56 Radio
System description: Radio
Software number: 6RD035187B
Software version: 5814
Hardware number: 6RD035187B
Hardware version: 541
Serial number: VWZZZ4H6290655
Long coding: 16000400040005
Trouble codes:
00856 - Antenna, on radio Open circuit
Intermittent
Priority: 5
Frequency counter: 12
Driving cycle: 22
Mileage: 220311 km
00872 - Left rear bass speaker Open circuit
static
Priority: 5
Driving cycle: 10
Mileage: 220438 km
00873 - Right rear bass speaker Open circuit
static
Priority: 5
Driving cycle: 10
Mileage: 220438 km
61 Battery Regulation
System description: Batt.regelung
Software number: 7E0907534
Long coding: 330B7A73
Subsystems:
System description: J367-BDMConti
Software number: 7E0915181K
Software version: 1050
Serial number: 75885700001707250043
Trouble codes:
02256 - Static current Upper limit exceeded
Intermittent
Priority: 7
Frequency counter: 5
Driving cycle: 62
69 Trailer Control
System description: ConWysTrailer
Software number: 1K0907383F
Software version: 0100
Hardware number: 1K0907383F
Serial number: 00000132425721
Long coding: 0100000100000000
Trouble codes:
I believe the two above are related.P204F00 - Reductant System Performance Bank 1
Intermittent
There is a newer engine software available - which should cure (false alarms) of P204F00 and P20EE00.Software number: 04L906056KL
