P0673
rewer
Spanish member
good morning, I have a problem with my t6, it gives me a p0673 error, the glow plug has been changed but it continues to give the same error, what do you think would be the next step to check? cables? relay?
Please translate your question using Google translate.
Something to do with glow plug on cylinder 3 so swap it with one from another cylinder clear the code and retry if the error stays on cylinder 3 start looking at the wiring fused link etc
This plug no is posible change with the cilinder this plug have a presure sensor
Check for 4.4v at the plug if no voltage it could be wiring if there is voltage its the plug.
Disconnect the glow plugs and measure the resistance of each one and compare.
Does anyone have a wiring diagram for the glow plugs?
What engine code? Year?
2.0l diesel engine , CAAA,CAAB,CAAC,(7L3) Glow plugs
