Oil Ash Residue Limit
If you have a regen in progress it's better to do a short drive, the ECU will only run a regen at idle for about 5 minutes before bringing it to a controlled halt - it will start again next drive as soon as it can.
It's still very much worth letting it do that, if you just turn off then everything is at a high temperature and the excess fuel injected to get those temperatures can drain into the oil sump while parked.
That's the difference with a forced regen - it will try and complete no matter what and as noted things will get very hot. Keep that in mind this summer if you park up in a handy layby to save disturbing the neighbours - check for tinder dry vegetation and rubbish!
I monitor mine on long trips using VAG DPF and try to keep in the habit of dropping a couple of gears and getting the revs up to about 3k to both help the temperature and put the engine under load occasionally.
Your regen times/distances seem largely the same as mine. No harm in doing the research and making a plan but I'd leave it alone for now your first clue it's actually full will be when those start happening more frequently.
This is very helpful information to know yours does similar. I bit the bullet today on getting the DPF cleaned. Van is back in getting new EGR cooler & pipe so while that's happening they are going to clean the DPF. My expectation is that I'll hopefully have a very smooth running engine after it's all done.
