oil around the rocker cover 12k miles
Possible overspill from oil change?
Get some brake clean to clean it up....
Then monitor for Future leak.
At 12k miles from new it's due it's 1st oil service.... Had that been done,?
bought van with 8000k miles and had serviced then oil is slowly dripping from rocker cover area and you can see the oil under the van you can see the drip here from under the
It needs a complete degreasing to locate the leak whether yourself or somebody else is going to repair.
Once thoroughly clean have a 10 minute drive and check for the source.
Hi, did you ever get to the bottom of this leak?, mine seems to have developed almost exactly the same leak from the same place.
Hi, @AIDY, i have the same issue, I think its coming from the rubber seals in the rocker cover around the Injectors. Be interest to know what you found? Cheers Steven
