OBDeleven coding
Mike Y
Hi all
1st post on this forum as I picked up my 2017 Caravelle last weekend. Owned an ex-AA T4 for 12 years so just getting used to being back in the van club!
I purchased an OBDeleven Pro (VAG) device to read/clear fault codes and to do some simple mods. I'm thinking:
Needle sweep
Auto-lock at 10 mph, unlock when key removed
Cornering lights with turn signal
Wiper service mode
Emergency braking lights
Tear-drop wiping
I know the last five can be done with credits/apps, but I was wondering if they can also be coded manually, given I've bought the pro subscription (without also having to buy credits)? If so does anyone have any how-to guides for a beginner please?
Mike Y
Ok so I did a bit more reading and then was feeling brave so just had a go... I've detailed what I did below in case anyone else had the same questions...
Big Dash MPH (also enables alt speed dis. on MFD option)
Control Units > Dashboard (17) > Long Coding > Country Version > changed "Great Britain" to Rest of World (now wondering - should this actually be "Australia"?)
Auto-lock (above 10 mph)
Control Units > Central Electrics (09) > Long Coding > Auto-Lock (Automatic Locking above 15 km/h > changed "Not active" to "active"
Auto unlock (when removing key)
Control Units > Central Electrics (09) > Long Coding > Auto unlock > changed "Not active" to "active"
Cornering lights with turn signal (as already on for me)
Control Units > Central Electrics (09) > Long Coding > Cornering/turn lights via turn signal > was already "active"
Wiper service mode
Control Units > Central Electrics (09) > Long Coding > Service position for front wiper > changed "Not active" to "Active" (this might have already been on already)
Emergency brake flashing (brake light)
Control Units > Central Electrics (09) > Long Coding > Emergency brake flashing (brake light) > changed "Not active" to "Active"
Tear Drop Wiping
Control Units > Central Electrics (09) > Long Coding > Tear Drop Wiping > changed "Not active" to "Active"
Tried needle sweep:
Control Units > Dashboard (17) > Adaptation > "Indicator Celebration" > Active (was Not Active) - but get an error message - is that to do with Country version being set to Rest of World rather than Australia?
Also, is there a way to get the fan speed to display when on Auto mode? I can't seem to find this option but have seen it mentioned on other VAG forums .
Wiper service mode
Tear Drop Wiping
Tried needle sweep:
High @Mike Y
Welcome to the forum and thanks for posting your results.
I’m lucky to be an OBDeleven early adopter and earned credits daily by watching short promo videos.
I then used some of the credits to activate some of your above ones.
I couldn’t get the large MPH to activate though and will try your solution when I can.
I’m sure others will be along shortly with more help than I can currently offer.
