NXT Coilovers
rocking robin
I have just had fitted a set of nxt coilovers and i have a creaking from the rear set, went back to the guy that fitted them he checked them and used some red grease on and checked with solow and was told that this can be a problem with panel vans that do not have a lot of weight in them ? i have done about 1500 miles on them.
Id be checking that they are fitted correctly.
Putting the rear spring / adjusters in the wrong ways round, ~ (with the adjuster at bottom, rather than at the top where it should be..)
Also that they have fitted rubber spring seats onto the arms at the bottom, as I've seen a number of vans without these fitted.
