Have you had much done by these guys? Heading towards my cambelt change and need to find someone locally.Sunset VW in Derby.
Yes. They did a lot of work for my on my T5 Shuttle removing the rear air con unit when I converted it. Then loads of work on the 5cyl diesel unit. I use them for my servicing on my T6. I think they quoted just over £400 to do my cambelt. 20/10 racing in Little Eaton quoted a bit under £400. I use them for all my other servicing & MOTs.Have you had much done by these guys?
Can anyone recommend anywhere in the Notts / Derby for servicing?
Still under warranty til September and done 31K
I was going ask a similar question
@Tourershine do you still recommend VW in Leicester ???
Don't use the Imperial commercials VW in Beeston. For anything Bunch of MUPPETS !
Oh hello mate.
Yes VW Leicester have always been great to me.
My T6 is due a service at 40k 17 reg 3 yrs old.
Other than buying the original parts form Vw which brands should I look at getting that are best match OEM quality.
oil filter
Air “”
Pollen “”
Fuel. “”
Also needs rear discs / pads
Thanks guys
I use Sunset VW in Derby, recommended to me by a few people on here and they have been ace. They are an independent but all VW trained and itemise VW only parts on the bill.Hi, wondering if any body found or uses a dealer in the mentioned area that they would recommend, that isn't Motus. Have had a very bad experience from the Derby one and the Nottingham one wasn't much better. I have recently taken the extended warranty, and now have an engine warning light related to Ad blue. So hoping covered by the warranty . Any recommendations are welcome. Thanks
