I hope that the original poster of this thread finds the ideal vehicle for him and his boys. It is quite a task deciding what is best , what is important and what is not important and that may be different for each of us. I believe that one need to see and hear many fact about a multitude of things. I think one should be clear in ones mind why a vehicle may be rejected and for some time know people have been put off or decided against buying a vehicle with a certain type of engine because it is or may be problematic. It is unfortunate that the wreath that has been hung around the neck of this engine is called Twin Turbo and that to avoid Twin Turbo one sure way is to buy a 150 which only has one turbo. The fact is there are a few engines that have Twin Turbos and 2 engines that produce 204bhp another coincidence that has little to do with its failing. Their is only one engine that has earned a reputation for being problematic and that is the one with a designation of
CXEB
- 204ps Bi-Turbo CXEB T6 Engine & Turbo problems -
Looks like im the latest patient of the CEXB engine issues.
(possibly the 2016-2018 range as there is a mention that the CXEB Block etc was revised in 2019)
(the CXEC 199ps Bi-Turbo was released 2019> and revised )
in sort it looks like its either Turbo or Engine failure.
here is some background:
204ps Bi-Turbo CXEB Engine & Turbo problems...
If someone was trying to avoid an engine that may be dubbed an albatross then that is the best way to avoid it and not to look at any other label to exude it it is the engine designator not its power output or the number of turbos so if again it is the CXEB and no other engine has any doubts thrown over it and at this time it would have been evident if any other engine was problematic because enough time has passed to ensure that all engines types will have covered enough high mileages by now that it would be common knowledge if that where so.
If someone had another reason why to avoid certain engine type then that is up to them but to be clear it would not be because it has twin turbos and that is problematic and it would be a shame if a very good vehicle was avoided by a misunderstanding.
