Noise from engine bay not turned ignition on
Grainfoot
When opening bonnet can hear what sounds like a very quiet fan, engine not been running ignition not switched on. It goes off after a short time. It does use battery power as I have been checking battery voltage during lockdown and can see voltage climbing again after it stops.
Anyone know what it is.
Dont have LED headlights, key not in ignition not sure why fuel pump would prime,!
Some VWs prime the lift pump in anticipation of you starting the engine so that the High-pressure fuel pump driven by the engine doesn't run dry. But there is also a water pump that circulates.
