After purchasing a van just before lock down I'm very much stuck in the planning stage, completed the sound deadening and the majority of the insulation while waiting to get pop top and windows fitted, so need to plan cabling etc before fitting carpeted panels etc
I'm expecting to use the van for the odd night or two off the battery, anything more I would be looking at a camp site with electrical hook up
I'm very much in the keep it simple camp, requirements/rough plan below:-
240V :-
Already installed cable under bonnet ready for RCD mounted under the seat (already purchased with 16 and 6A breakers)
Feeding Leisure battery charger and 3 x sockets
12v :-
2 or 4 USB sockets to charge phones
Around 4-6 LED spot lights in addition to LED strips around the kitchen area
Fridge (probably CRX50)
Eberspacher Heater Control
Water pump for tap
As can be seen apart from the fridge (approx 1 amp/h) there's nothing too resource hungry
Would it be feasible to go with a Solar panel/charge only and not bother with a B2B charger, as there are some good deals on 150W panel kits around (£150ish), as stated anything more than a couple of days I would be looking at hook up which would charge the leisure battery (110-130Ah)
Location for equipment:-
Battery, RCD and 240V charger under drivers seat (and B2B charger if needed)
Cabling from battery to fuse box/breakout in rear wardrobe, would this need to be 16mm squared or is that a bit over the top?
From then I'd need 4mm to fridge and 1.5mm for the LED lights and 2.5 for the USB chargers, does that sound right?
Thanks for any help....
240V :-
12v :-
Water pump for tap
