Saturday,11,July,2026,10:47:23:39739
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 26.6.0.1 (x64) HEX-V2 CB: 0.4713.5
Data version: 20260708 DS377.1
www.Ross-Tech.com
VIN: WV1ZZZ7HZLH013*** License Plate: AK
Mileage: 197178km-122520mi Repair Order:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F 75
VIN: WV1ZZZ7HZLH013382 Mileage: 197178km-122520miles
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
Address 01: Engine (J623-CXHC) Labels: Redir Fail!
Part No SW: 04L 906 056 SC HW: 04L 907 445 M
Component: R4 2.0l TDI H01 9970
Revision: 23301001
Coding: 001140144344050900000000000000000000000000000000
Shop #: WSC 00012 790 00069
ASAM Dataset: EV_ECM20TDI03004L906056SC 005007
ROD: EV_ECM20TDI03004L906056LE_005.rod
VCID: 005E62C6AA8AB0BADB2-8054
VINID: 9E606AAAA1D8A9C6000430C80898F35FBA
1 Fault Found:
27277 - System Voltage
P0562 00 [00100011] - Too Low
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 196341 km
Date: 2026.06.18
Time: 10:50:18
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 21 °C
Intake air temperature: 0 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.289 V
Air mass at air mass meter 1: 0.0 kg/h
Standardized air flow ratio: 1.000 counts
Exhaust recirculation valve 1 bank 1: position feedback – actual value: 0.78 %
Throttle valve adapter 1 bank 1: position feedback – actual value: 0.00 %
Charge air pressure: specified value: 0.002 bar
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1015 mbar
Mean injection quantity: 0 mg/stroke
Index of current engine mode: 4
Index of next requested engine mode: 7
Index of engine target mode: 7
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7LX-614-517-V1.clb
Part No SW: 7LB 614 517 A HW: 7LB 614 517
Component: ESC_base H01 0700
Serial number: 08504489190913
Coding: 305524524848EE880C5724AC12687706392320B8
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
ROD: EV_Brake1ESP90iBOSCHVN46X_002.rod
VCID: 3E22DC3E90FE064AE9E-806A
2 Faults Found:
0600 - Function Restriction due to Faults in Other Modules
U1113 00 [00001000] - -
[Dst_DstReqNotActuatedEpsPerfOk]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 38
Mileage: 197178 km
Date: 2026.06.18
Time: 10:43:31
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [00001000] - -
[Scl_LWI_Lenkradwinkel_Error]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 38
Mileage: 197178 km
Date: 2026.06.15
Time: 00:11:49
Address 08: Auto HVAC (J301) Labels:* Redir Fail!
Part No SW: 7LA 907 426 B HW: 7LA 907 426 B
Component: AC Manuell H01 0502
Coding: A03110000810000001000800504001050000000000000000800000000000
Shop #: WSC 00012 790 00029
ASAM Dataset: EV_AirCondiBHTCT6PA 001004
ROD: EV_AirCondiBHTCT6PA.rod
VCID: 42DAA8CEE40662AA8D6-8016
Rear air conditioning block 1:
1 Fault Found:
1048838 - Functional Limitation due to Energy Management
B10CD 00 [00001000] - -
[Funktionseinschränkung durch Energiemanagement Ruhestrom]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 38
Mileage: 197178 km
Date: 2026.06.15
Time: 00:11:51
Voltage terminal 30: 11.1 V
CAN input signal(s) status-Transport mode: On
CAN input signal(s) status-Static current measuring mode: OFF
CAN input signal(s) status-Front windshield wiper: OFF
CAN input signal(s) status-Energy management: shut-off stage: Deactivation stage 2
CAN input signal(s) status-Wipe wash: OFF
CAN input signal(s) status-Rear window heater actual value: OFF
CAN input signal(s) status-Back-up lamps: OFF
CAN input signal(s) status-Actual value of windshield heater: OFF
Blower reduction: No switch-off: no reduction
Address 09: Cent. Elect. (J519) Labels: 2QX-937-BCM-V1.clb
Part No SW: 2Q5 937 090 HW: 2Q5 937 090
Component: BCM T6PA Std+ H10 0935
Serial number: 01101931000289 Dataset Number: V03935315CB 0001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_BCMA0 205001
ROD: EV_BCMA0_205_VW27.rod
VCID: 74B63E16EE329C1ACFA-8020
Rain/Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 050 0105
Serial number: S4Y19M11D06H04M38S57
Coding: 02B8EE
Driver door control module:
Subsystem 2 - Part No SW: 7L1 959 405 B HW: 7L1 959 163 B
Component: FHSG_DRV 001 0002
Serial number: 00000000000033023509
Coding: 1F000F
Front passenger door control module:
Subsystem 3 - Part No SW: 7L1 959 406 B HW: 7L1 959 164 B
Component: FHSG_PSG 001 0002
Serial number: 00000000000035234207
Coding: 050007
Anti-theft alarm system sensor:
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY1925510AW
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000047859676
No fault code found.
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058419309 Dataset Number: V03935304BK 0001
Coding: 0451151801
ASAM Dataset: EV_EPHVA18AU3700000 009046
ROD: EV_EPHVA18AU3700000_010_AU37.rod
VCID: 50FE92863A6A803A0B2-8004
1 Fault Found:
13637426 - Databus
U1123 00 [00001000] - Received Error Message
[ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 38
Mileage: 197178 km
Date: 2026.06.15
Time: 00:11:52
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Dataset Number: V03935303EM 0001
Coding: 2A00600201FF8748949C815560508700000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003016
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 43D4ADCAFB1C6BA2860-8016
3 Faults Found:
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 38
Mileage: 197178 km
Date: 2026.06.15
Time: 00:11:51
Voltage terminal 15: 11.0 V
Control Module temperature: 43 °C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.72 m/s²
Adaptive distance regulation: status: ACC_irreversible error
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 38
Mileage: 197178 km
Date: 2026.06.15
Time: 00:12:01
2055 - Databus
U1122 00 [00001000] - Implausible Message
[FAULT_ALP_STEERINGWHEEL_INIT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 38
Mileage: 197178 km
Date: 2026.06.15
Time: 00:11:51
Address 15: Airbags (J234) Labels:| 2Q0-959-655.clb
Part No SW: 2Q0 959 655 AD HW: 2Q0 959 655 AD
Component: VW22Airbag 013 0506
Revision: -------- Dataset Number: V03935308TZ 0001
Coding: 8800C00000000000400000CF008C40000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 7F5CE13AD774CF42A28-802A
Address 17: Instruments (J285) Labels:| 7LA-920-XXX-V1.clb-SRI3
Part No SW: 7LA 920 941 HW: 7LA 920 941
Component: KOMBI 204 6750
Coding: 27A40A002480260001882A010401000000200000
ASAM Dataset: EV_DashBoardVDDMQBAB 009069
ROD: EV_DashBoardVDDMQBAB_VW27.rod
VCID: 7DA01B32DD78DD52B04-8028
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 27101911602262 Dataset Number: V03935310HZ 0001
Coding: 030100044F05730000000018000F00010001070000000000000000000000
GVL: 01443C0000000000400080008000480000000000000000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_SK25.rod
VCID: 70BE32069A2AA03A2B2-8024
Generator:
Component: 4-01-09-01-04
Multi-function steering wheel control module:
Subsystem 2 - Part No SW: 3G0 959 442 F HW: 3G0 959 442 F Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H06 0110
Serial number: PR6-0440066312190985
Coding: 2C1D00
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 7E0 915 181 N HW: 7E0 915 181 N
Component: J367-BDMConti H03 1052
Serial number: 773433010019102502E6
2 Faults Found:
197149 - Generator
U1052 00 [00001000] - No Communication
[Generator (LIN#1) Timeout]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 38
Mileage: 197178 km
Date: 2026.06.15
Time: 00:11:51
Terminal 30 power supply: 11.0 V
Terminal 15: On
8526361 - LV Energy Management
B1802 F1 [00001000] - Warning Triggered
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 38
Mileage: 197178 km
Date: 2026.06.15
Time: 00:11:51
Terminal 15: On
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 7LA 909 144 F HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7150
Dataset Number: V03935309JN 0001
Coding: 0106
ASAM Dataset: EV_SteerAssisMNB 002012
ROD: EV_SteerAssisMNB.rod
VCID: 45D0B3D2F5285592A84-8010
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 3G0 035 869 B HW: 3G0 035 869 B
Component: MU-E-D-ER 715 0740
Serial number: 30101900021637 Dataset Number: V03935316KK 0001
Coding: 066401003C00000041110101008000001F0000D60000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001044
ROD: EV_MUEnt4CGen2LGE_VW27.rod
VCID: 2B04E56A738C83E25E0-807E
Address 75: Telematics (J949) Labels:* Redir Fail!
Part No SW: 5WA 035 282 HW: 5WA 035 282
Component: OCUGen3Low H14 0083
Serial number: 0000000908NVZC3 Dataset Number: V03935314UT 0001
Coding: 06462000196818208005460160000607
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low_002_VW27.rod
VCID: 015867C2A180B9B2D4C-8054
3 Faults Found:
7170 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Multi Function Display (0x0F) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 40
Mileage: 197178 km
Date: 2026.06.15
Time: 00:02:35
Voltage terminal 30: 11.0 V
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
[Functional restrictiondue to insufficient voltage]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 197178 km
Date: 2026.06.15
Time: 00:14:01
Voltage terminal 30: 5.5 V
13631561 - Internal Control Module Memory Check Sum Error
B2000 49 [00001001] - Internal Electronic Failure
[Control unit defective Analog circuitry]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 6765 km
Date: 2020.03.17
Time: 02:36:16
Voltage terminal 30: 12.3 V
End----------(Elapsed Time: 01:32, VBatt start/end: 12.9V/12.9V)-----------
------------------------------13 Faults Found------------------------------
