Multiboard flex query!
Victorvalle101
Help!!
Do i absolutely HAVE TO removed table and mid row seats in the Caravelle T6 to get my flex in situ?
Brand new to all this and I’m going to build it and fit it tomorrow. Just wondered if anyone knew if I could unfold it without removing seats? Seems like a bit of a b**lache but if needs must…
Help!!
Normally the Flexable Multiboad goes in the Boot or Trunk if you are from the US not sure what our Australian and New Zealand cousins call it. By all means remove the addition seats and table but it is not absolute necessary to do so. From a fellow Carravelleian!:)
Thanks. Definitely will be fixed down in the runners in the boot. Just wondered if there was a way to lay the bench seat flat and open up the board to make the bed without removing the the mid row seats. Videos seem to have them out but what a palaver! 🤣
Well ours have been out for a little while less need since daughter went to uni and the table too. We appear to be carting more stuff about now. We did however use the board withe middle row did not need to extend the board as we are not giants. The board is superbly made but I think that I would prefer a system where there is less pushing and pulling, putting things into position when parked up. All that should be needed is to put the bed or seat flat and place a cushion and that should be it. Not much fun in the poring rain or worse with the midges buzzing about just trying to sort the bed out. Once it is all in place it is comfortable enough it is just all the sliding this and that in preparation. :)
