MFD (MFA) Activation in 860 S Instruments Panel
an_qwerty
Hello everybody, i need to activate MFD,
I have outboard temperature and service counters on display. New light and wiper selector with Cruise control and MFD are installed (Cruise for the future, wires to BCM and Engine ECU not connected yet, but wires for MFD connected) VAG code: 7E0953507C 9B9.
Time for coding at now.
I tried to set bit №3 in Byte №1 to "1" in 17-Instruments, but VCDS said Error 31 : Request out of range.
Does anyone know how to fix it?
I have read a lot off reports of successful activation, nobody mentioned a problem.
Auto-Scan in attachment.
Hoping for some help.
Not sure . . . . . but possible VCDS version problem?
The Current version is:
Release 18.9.0
Data Version 20180927
your listed version . . .
VCDS Version: 17.8.1.0 (x64)
Data version: 20171130 DS276.6
@mmi Done :) Like i sad, 1st byte changed. What about error in Radio module? 01044 - Control Module Incorrectly Coded
P.S. In BCM some options activated too
Code:
Address 17: Instruments (J285)       Labels:* None
   Part No SW: 7E0 920 860 S    HW: 7E0 920 860 S
   Component: KOMBI         H03 1107
   Serial number: 00000000000000
   Coding: 150F012100
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_005_VN35.rod
   VCID: 387E107C83538A8669-806C
Good to hear that the coding was successful. Yes indeed, the change is in the byte №1 bit № 3. Just remains the question why the VCDS didn't do that - a communication glitch perhaps :unsure:
Any pictures of your MFD before/after the change :). Any more details to share? Links to other websites?
What did you change in the BCM?
Never seen the radio you have so can't help there :(. Far fetched but just thinking if module 75: Telematics (1K8 035 284, Online Connectivity Unit) needs to communicate with the radio or other way round... Anyways the faults in both modules are intermittent so not easy to catch :(.
PS. Welcome to the Forum! :thumbsup:
Before change in the center of display you can see only outboard temperature, after coding see photos and in additional "Empty Space in tank in litters" (Photos not mine, report from another car for eg. Установка и активация БК на Морожке — бортжурнал Volkswagen Polo Hatchback Морожка 2011 года на DRIVE2 (Rus Lang)).
In BCM added:
1) Auto-Locking doors in moving
2) Auto-unlocking when ignition key removing
3) Mirrors heating enabling with rear window heating
4)Horn without ignition
About module 75, it's venajan "SOS-Button", in self-testing with voice system said "Crash-sensors is OK" May-be its connected to radio, because it's using microphone and speaker, wich in upper side of console (above radio)
Cruise controll activation in future... But not on winter, too cold)
4b78772s-960.jpg 9d78772s-960.jpg 68f8772s-960.jpg 82f8772s-960.jpg 3778772s-960.jpg 4378772s-960.jpg af78772s-960.jpg fb78772s-960.jpg
