Fitted both. Got the V1 on my van, and fitted the V2 on @ZipcodeUK 's van.
The profile of the "lip" on both the V1 and V2 is identical. The difference is the upper profile where it attaches to your bumper.
The V1 has what I relate to as "fingers" which give a number of raised profiles in the centre section of the splitter. It is through these fingers that you bolt through to the bumper.
The V2 does not have these, but one long raised profile along the centre section. The edges where the splitter wraps around the side of the bumper are again identical.
There is a picture of mine on page 5 of this thread but it is difficult to see the finger profiles. If you go back to the top of page 2, Amped has put a couple of website pics up which enable you to see the difference a bit clearer.
Good luck choosing.
Choices choices.....hardest thing in the world.Thanks daveyb
Now to decide on v1 or v2
Hi, splitter looks great.I haven't got one but think Black looks better than Carbon
No, I have fitted two without the need to remove the bumper.Hi, splitter looks great.
Does bumper need to be removed to bolt it on?
Thanks in advance.
Thanks for that, well done! I've just had a body shop tell me the bumper needs to come off to get to fixings!No, I have fitted two without the need to remove the bumper.
However, I highly recommend undoing the screws holding the front of the wheel arch liner to the bumper to give you a bit of access. There are then two or three screws on the underside of each of the front corners that you will need take out.
It's as fidelly as a fidelly thing and bolting through under the fog lights is particularly tricky. You'll scratch your hands a wee bit, but like I said, It's totally dooable.
As per my previous it is all easy till you get to bolt the two corners under the fog lights. Yes there is no doubt that taking the bumper off will make it a damn sight easier, however....I'm hoping to have a go fitting mine over the weekend. Got big fat hands so not looking forward.
