Mains battery charger max charge
Gas2
I have a 8A Intelligent Mains Leisure Battery Charger from Rayne automotive the spec says it will charge batteries up to 140 ah. Will this charge 2 x 90ah batteries connected in parallel ?​
yes. . . just slowly . . (assuming its a modern smart charger capable of charging AGM/SLA batterys?)
go a pic of the charger so we can double check for you?
more info:
this one?
if so, then yes. the 8A will be slit across the two batterys , so will charge at 4A each.
very rough calculations not taking into account DoD,SoC,DutyCycle, etc etc would show around 24 hours for a full charge.
2x90ah battery = 180ah / 8ah charger = 22.5hrs
180ah * 0.5(DoD) = 90ah -> / 8ah charger = 11.25
7 stage fit and forget automatic 8A leisure battery charger.
Automatically charge your leisure battery when hooked up to the mains.
Product description
  • Will charge both wet lead-acid and AGM Battery banks of 40Ah to 140Ah.
  • Not suitable for LiFe Po4 batteries
  • Fitted with M8 eyes for DC battery connection
  • UK 3 pin 13A plug fitted for 240V connection.
