Magical wizardry is happening that shouldnt be happening. Lights and 2x 6th gears.
bullracing
I have a 150 2016 shuttle turn camper. It was shuttle but now a camper.
Yesturday I noticed some weird stuff happening.
I have fitted the traveline lite footwell lights and the saxoboy vw puddle lights so these have been wired in different to factory.
I have removed the rear interior sensor but the front is still active.
I have fitted a T6 MFSW but have not been able to get the cruise on yet until I buy a newer vcds lead. However I did not have this problem before or after I fitted the wheel so I do not thinkthe problem is related however I could be wrong.
The van had rear heating etc but all the wiring has been left and is in the pop top frame. The connectors are not connected to anything.
I was sleeping in the camper the other night. I lock the van using the button on near the elec windows and mirror adjuster. When I got up at night and lifting the pop top bed (I leave it down if on the rock n roll to make it darker and warmer) the footwell lights turned on. I tried it later by making a noise or moving without lifting the bed but they did not come on until I lifted the bed which was odd.
Driving home I noticed the footwell lights were on. No doors were open and the interior light switch was turned off. I turned it to open with the doors and the lights came on. As I accelarated and got to 4th gear they then started going on, off, on off etc smoothly.
So thats weird I thought.
Anyway to top it all off further I have a manual gearbox and going up hill it told me to change from 6th to 5th gear, totally normal BUT ................. I was in 5th gear. I stopped and went through all gears, I have all gears except a 5th gear. Instead of have 2x 6th gears.
What on earth is going on, is it haunted? I've had a pretty crap time with making it into a camper so maybe its cursed ha ha ha
Any ideas on what to try would be appreciated. I have no idea what it uses to know what gear it is in. The van has 14k miles on so is not a work van, It usually lives tucked away in the workshop.
The camper has 400w solar and 2x 110ah batteries but these are seperated from the van so there is 2 seperate systems.
Scanned it yesturday. A few faults. Cleared them and lights behaved as they should. No faults returned either. Rather odd as I would like to find out what caused it all.
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 15 17 18 19 25 5F 61 69
Mileage: 23250km-14446miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KM HW: 04L 907 445
Component: R4 2.0l TDI H02 6186
Revision: 23002001
Coding: 0019401C430401090000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KM 004013
ROD: EV_ECM20TDI03004L906056JT.rod
VCID: 020B54C69567A55FB1-8056
3 Faults Found:
14098 - Clutch Switch (F36)
P0704 00 [032] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 23009 km
Date: 2053.01.15
Time: 15:56:13
Engine speed: 1700.25 /min
Normed load value: 67.8 %
Vehicle speed: 87 km/h
Coolant temperature: 91 °C
Intake air temperature: 22 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.585 V
Unlearning counter according OBD: 39
Camshaft speed (RPM): 1458 /min
Camshaft adaptation intake bank 1: phase position: -0.6 °
16049 - Neutral Gear Sensor
P15A1 00 [040] - Implausible Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 89
Mileage: 22172 km
Date: 2052.01.00
Time: 14:38:31
Engine speed: 1999.50 /min
Normed load value: 97.6 %
Vehicle speed: 102 km/h
Coolant temperature: 90 °C
Intake air temperature: 19 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.593 V
Unlearning counter according OBD: 40
Transmission neutral position sensor voltage: 3.359 V
Neutral position sensor: upper adaptation value: 3.164 V
Neutral position sensor: lower adaptation value: 1.289 V
selected gear: 6th gear
30540 - Throttle Position Sensor (G69)
P0121 00 [032] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 22354 km
Date: 2053.01.03
Time: 00:44:47
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 16 °C
Intake air temperature: 0 °C
Voltage terminal 30: 11.757 V
Unlearning counter according OBD: 19
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Throttl.valve adapt. 1 bank 1: posit feedback - Spec.value: -0.01 %
Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 100.00 %
Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: 0.27 %
Throttl.valve adapt. 1 bank 1: posit feedback - Uncnd vlt: 4.740 V
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 42505000001532
Coding: 307E40982566847E0C7B027CA48221D3790000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3F8D9D32A61508B79E-806A
No fault code found.
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 26061504650890
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF32036E19FC1BFD5-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 R HW: 7E0 907 047 R
Component: Climatic-T5 H22 0607
Revision: 00001002
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 3979F32AB8312687A0-806C
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0736
Revision: B9080001 Serial number: 0771 246150901
Coding: A0F4793A0A63349392284F642C6A9DD48DA4698960440970320400BF0840
Shop #: WSC 43013 002 104857
VCID: 68DF666E9B1B6F0F0F-803C
Subsystem 1 - Part No SW: 7E0 959 801 K HW: 7E0 959 801 K Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8654
Serial number: KU0KU027081552393158
Coding: 1400B0
Subsystem 2 - Part No SW: 7E0 959 802 K HW: 7E0 959 802 K Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8654
Serial number: KU0KU007091552501498
Coding: 0400A0
Subsystem 3 - Part No: 7E1 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 5 - Part No: 7E1 951 171
Coding: 000000
Subsystem 6 - Part No SW: 7E0 959 442 HW: 7E0 959 442
Component: E221__MFL-DC1 H02 0103
Serial number: 39170002737200037506
Coding: B0FFFF
2 Faults Found:
03301 - Response Closing Status of Drivers Door
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 28
Mileage: 22336 km
Time Indication: 0
Date: 2020.05.15
Time: 14:25:27
50990 - Unknown Error Code
Unknown - 014 -
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 7
Reset counter: 254
Mileage: 22169 km
Time Indication: 0
Date: 2020.04.04
Time: 14:30:41
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 E HW: 7E0 959 655 E
Component: VW10Airbag00C 008 0016
Revision: -------- Serial number: 003PJ000EW8F
Coding: 000000000000000000000000000000003043
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750_VW12.rod
VCID: 387FF62E833B3F8F5F-806C
Crash sensor for side airbag: driver side:
Serial number: 3495ZRB40693FGI6E89U
Crash sensor for side airbag: front passenger side:
Serial number: 3505ZRB40573FGI67P5P
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 L HW: 7E0 920 970 L
Component: KOMBI H05 1008
Serial number: 00000000000000
Coding: 710D010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 3365C1029A5DDCD76A-8066
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 273 HW: 7E0 963 273
Component: STH-T5GP2 002 0007
Coding: 4101
Shop #: WSC 02759 790 50316
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001010
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 6ADB1C668D175D1F19-803E
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0736
Revision: B9080001
Coding: 042305
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 1008
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09.rod
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 E HW: 1K8 035 150 E
Component: MU-E-D-ER 857 6495
Serial number: 28081500012536
Coding: 065700003C00000041111101008000001F0000860000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_VW12.rod
VCID: 275D25525E85A077C6-8072
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0736
Coding: 030B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 G HW: 7E0 915 181 G
Component: J367-BDM H08 0223
Serial number: 52232F34531261520254
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H12 0100
Revision: 3A001001 Serial number: 00000495347083
Coding: 0100000100000000
Shop #: WSC 12345 123 12345
VCID: 306FCE0E634BE7CF17-8064
2 Faults Found:
02562 - Trailer; Brake Lamps
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 3
Time Indication: 0
02563 - Trailer; Right Tail Lamps (M61)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 3
Time Indication: 0
End-------------------------(Elapsed Time: 02:54)--------------------------
These have returned again. I cant figure out if they are all linked. The clutch, tps and neutral must be linked but which one is at fault? Changing all 3 would be a little ott?
I will take the door card off to see if its the saxoboy puddle lights causing the problem with the door, I had problems with the crimp thingys so that might solve that one, if not I will look for a door switch.
The door shows shut when it should be and when the interior lights turn on when your driving it does not show a door opening on the display so there must be a fault not related to the door but in between the door and bcm, bcm is picking it up as a door fault and sounds the alarm.
