lowered 50mm on HRs - wheel alignment ?
teamfly
McLife Sentence
Hi , had my LWB T32 lowered on H&R -50 mm springs .
Ran my t5.1 on -40mm and didn't bother with wheel alignment or tracking check .
Should I get wheel alignment check ? quoted £120 plus vat , just tracking , or probably ok as is ?
Van almost new.
That seems expensive, I didn’t get my
Tracking checked initially after lowering and started to each tyres so booked it in with local tyre shop who have a hunter 4 wheel alignment system and they charge £30 for checking it and more of it needs adjusting
Always get an alignment. Even if you're van is loaded and you know it will be a constant load.
You can only adjust toe on these vans so £60-70.
I thought 120 + vat was expensive , So , is toe in check the same as tracking ?
Adjusting the tracking changes the toe in/out.
Loads of stuff on YouTube explaining suspension set up. Just one example....
